Author Topic: M127 injector fuel line leak  (Read 4133 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: November 06, 2016, 22:55:56 »
My number 6 injector fuel line is leaking and I'm about to order a new line. I'm fairly sure that the fuel line part numbers are numbered consecutively, beginning with number 1 (127-070-12-33), and ending with number 6 (127-070-17-33).
Before I order a new injector line I'd like to confirm one more time that 127-070-17-33 is the correct MB part number for injector line #6 (injector 6 is closest to the firewall).  Can anyone confirm? thanks,,,charles
Re: M127 injector fuel line leak
« Reply #1 on: November 07, 2016, 16:25:46 »
Just checked the big parts book
127 070 17 33 listed as:
Delivery line (for 6th cylinder)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: November 07, 2016, 16:48:09 »
outstanding,,,thank you Jonny
« Reply #3 on: November 07, 2016, 16:52:07 »
Is it leaking at the fitting or is it leaking at the gland nut?
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: November 07, 2016, 18:05:30 »
It's leaking at the 17mm fitting. I could probably tighten it a bit more to stop the leak,, I'm just not comfortable tightening it beyond specs. thanks,,charles
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #5 on: November 07, 2016, 18:39:42 »
Has anyone ordered a new injector line from MB lately? I just hope it'll be yellow cad like my other ones....
mbazinet
« Reply #6 on: November 29, 2016, 01:06:59 »
It will arrive stock stainless finish  no coating   did mine a few months ago  stock from MB
« Reply #7 on: December 10, 2016, 08:13:29 »
Try using some grease on the fitting compression surfaces before tightening. It helps things slide together smoothly and tightly,  without binding or gaulding.
