Author Topic: Transmission and matching numbers ?  (Read 2556 times)
JChristo
« on: November 09, 2016, 14:28:50 »
Gentlemen I just recently had my transmission replaced a few months ago. I was faced with question of do I keep my original transmission and rebuild at $3700 or swap over to a rebuild. I was in a rush and swapped over to the rebuild.
Now I am restoring her back to original 180g and have taken both transmission and engine out.
 I have a 1969 280sl original Australian delivery so I kept the ID plate from my original transmission but unsure of what my mechanic replaced it with whether it was from a 230 or 280
Strangely enough the original ID plate read 280 SE which was correct on the data card.
I have attached a picture of the new transmission with its ID number. Can anyone tell me
1. Is my my car worth more with the original transmission in there and should I chase it down and rebuild.
2. Is having the original ID plate enough.
3. Does it matter that it was replaced.
If anyone can shed some light on this topic of discussion that would help me
Thanks for taking the time.
JC
Jimmy CHRISTO
Jimmy@bjbac.com.au
1960 190 SL Silver on Dark red
1967 280 SL ZF 5 Speed Ruby Red
1968 280 SL White on Blue
1969 280 SL Silver 180g on Black
1969 300 SEL 6.3 Silver on Blue
1971 280 SE 3.5 Cab Silver on Black
1971 280 SE 3.5 Coupe Autumn fire on white
1972 280 SEL 3.5 Silver on Blk
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Transmission and matching numbers ?
« Reply #1 on: November 15, 2016, 14:04:06 »
Hi JC,
I replied to your PM also have moved you here to the right area. I know someone will respond to your questions.
Dieter
