with our official
Pagoda SL Group logo
from our official partner.
Research & Development
lightweight flywheel
Topic: lightweight flywheel (Read 6195 times)
srisant
November 11, 2016, 00:27:50 »
Has anyone make aluminum flywheel for 230sl?
Associate Member
Platinum
Canada, ON, Port Lambton
Re: lightweight flywheel
November 11, 2016, 04:46:00 »
I've never heard of one but I suppose you could get one made if you really wanted one badly enough.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
srisant
Reply #2 on:
November 11, 2016, 11:57:01 »
Sound expensive to have one off made.
Montreal V8
Reply #3 on:
November 12, 2016, 18:13:40 »
What, if any, would be the advantages ?
Full Member
Platinum
USA, CA, Fallbrook
Reply #4 on:
November 12, 2016, 18:29:25 »
Engine can 'spool up' (climb in RPMs) quicker?
Jack Jones
Full Member
Silver
Canada, ON, Milton
Reply #5 on:
November 13, 2016, 02:47:59 »
On the other hand you loose some of the driveability since the engine will stall easier. Not something I would do on a vehicle driven on the street.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
GGR
Associate Member
Platinum
USA, DC, Washington
Reply #6 on:
November 13, 2016, 17:59:05 »
A lighter flywheel will make quite a difference in the same way lighter wheels do. Some explanations here:
http://www.w8ji.com/rotating_mass_acceleration.htm
There won't be power gained, but the car will accelerate faster as it it was lighter.
The heavier the car, the less the flywheel should be lightened. For road use, the flywheel can be lightened a bit, but not too much or taking off from a red light may be quite an exercise with the clutch pedal, especially with a taller rear end ratio.
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #7 on:
November 16, 2016, 07:41:04 »
Mark Bull (mkbull here?) made a run of steel flywheels a few years ago. He might be a good person to talk to.
