Author Topic: Chain tensioner ???  (Read 2820 times)
cfm65@me.com
  • Cape Town, South Africa
Chain tensioner ???
« on: November 14, 2016, 14:22:08 »
Hi Gents,
Please help.
I have found the bolt in the picture below to be loose. It is a 10mm bolt, about 19mm long, with the end rounded (by hand). It screws into the front of the cylinder head, between the two oil bypass bolts.
Is the bolt supposed to hold the tensioner in a 'loaded, pre-tension' position? Or what is the function of the bolt?
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Chain tensioner ???
« Reply #1 on: November 14, 2016, 15:11:37 »
This bolt is not needed unless your car has AC.  It is a mounting point for the air conditioner bracket if you had AC. It does not thread into an oil or coolant passage, so it is normally left off if no AC is installed.
cfm65@me.com
« Reply #2 on: November 14, 2016, 16:54:28 »
TKS Joe,
Much appreciated.
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
