Become a
Full Member
Emergency Contact List
distance chainj to bolt
Topic: distance chainj to bolt (Read 3019 times)
450sl
Full Member
Silver
Netherlands, Gelderland, zelhem
November 16, 2016, 13:53:58 »
Gents,
I am rebuilding my engine and need to make a alu shim for the m12 bolt.
How much clearance bolt to chain is required?
Mark
450sl
Full Member
Silver
Re: distance chainj to bolt
November 16, 2016, 14:02:45 »
pic
450sl
Full Member
Silver
Reply #2 on:
November 29, 2016, 09:34:32 »
Finally i machined a washer of 3mm thickness.
A warning for not using any washer : bolt is about to hit the chain .................
Mark
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Reply #3 on:
November 29, 2016, 14:48:20 »
Mark, If your car has power steering, then the fluid reservoir is held in situ with this bolt. It takes up the extra clearance you are having an issue with. Also the gasket sets come with an aluminum seal washer to use as well.
Full Member
Platinum
USA, OH, Blacklick
Reply #4 on:
December 10, 2016, 07:58:40 »
I believe the special bolt has a aluminum seal on both sides of the PS bracket, if it has PS? Wi9thout PS it has one seal. The special bolt has a nice rounded shape end and is most likely case hardened on its tip.
Jump to:
=> Drive train, fuel, suspension, steering & brakes
