Author Topic: Adjustable AC pump bracket -- York to Sanden  (Read 3312 times)
Sam SL
  • Canada, British Columbia, Vancouver
« on: November 18, 2016, 23:25:35 »
Has anyone here used this adjustable bracket and is it redundant given that the AC system employs idler pulleys to take up tension.  I thought perhaps something can be gained for using the newer bracket with adjustability.
Sam
'71 280 SL  -- Green Queen
82 300D
92 500E
97 SL500
Re: Adjustable AC pump bracket -- York to Sanden
« Reply #1 on: March 01, 2017, 16:08:10 »
Interesting idea, but most likely will not clear the air filter panel.
Jack Jones
  • Canada, ON, Milton
« Reply #2 on: March 03, 2017, 19:42:50 »
Sam,
The adjustable mount is designed to be used when replacing a York style compressor on older domestic cars that did not incorporate an idler/adjuster bearing. It is usually best to fix the compressor to the engine and utilize the original adjuster.
Jack
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
