Author Topic: Great engine run stand  (Read 3542 times)
« on: December 03, 2016, 13:24:23 »
I am in the process of re-assembling my engine and am thinking pretty hard about building an engine run stand to test run it and make sure there are no leaks etc.  However, I have been on the fence as to if it was really worth the time and effort for one engine?  I have a small shop space and anything I build would either be given away or re-purposed on the next project so it seems hardy worth it.  Then I saw this video.  I guess the stand doesn't need to be as elaborate as I thought. I just need to get a friend to hold one side.
https://www.youtube.com/watch?v=JDvbarKnMXk
Re: Great engine run stand
« Reply #1 on: December 04, 2016, 17:18:41 »
Buy a cheapie like this one. Use it then put it on craigslist when your finished with it. Or take it apart and store it for your next endevour.
http://ebay.com/itm/361819879091?
« Reply #2 on: December 05, 2016, 21:03:22 »
Yes, testing the engine on a stand is a great thing as you can easily check for leaks, and then once run-in enough, re-torque the head and adjust the valves. Once it is in the car, you have then removed an infinite amount of variables. And if you do run across issues, they are easily fixed on the stand.
An engine test stand used for the purpose of breaking in, does not have to be fancy and can be made from wood. Just make it robust enough.
« Last Edit: December 06, 2016, 03:15:19 by wwheeler »
perry113
  • USA, NY, Rensselaer
« Reply #3 on: December 23, 2016, 23:43:47 »
Here's another awesome video of one on the stand running. Boy she purrs like a Kitten.
https://www.youtube.com/watch?v=QYwdKSKt5dc
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
