Author Topic: Sedan engine & correct engine supports  (Read 3837 times)
ggdtr5
  • United Kingdom, Scotland, Aberdeenshire
« on: December 08, 2016, 10:27:32 »
Hi there I am looking for some advice regarding my 1964 230SL.
I have recently got the car so I am still discovering things about it.
My car has a 127 sedan engine fitted , however I suspect that the engine supports have not been changed from the original SL engine,  there is a small dent on the inside of the bonnet where It looks like the engine rocker cover has been hitting.
My question is  how can I check if I have the correct supports and if they are incorrect where can I get some proper ones
Regards Graham
1971 280 SL
1972 Triumph TR6
1979 mini pick up
1992 Mini Cooper
1949 TED Ferguson tractor
2002 Honda S2000
2002 Honda S2000
Re: Sedan engine & correct engine supports
« Reply #1 on: December 08, 2016, 17:19:41 »
Graham,
the correct ones for a W113 engine should be stamped "127SL"; see photos and read discussion here: http://www.sl113.org/forums/index.php?topic=11554.0
Don't know what markings are on the supports for the sedan engine.
Jowe
« Reply #2 on: December 08, 2016, 20:50:46 »
And here in the Technical Manual: https://www.sl113.org/wiki/Engine/EngineSupportArms
Johan
Rick
  • USA, NV, Gardnerville
« Reply #3 on: December 08, 2016, 21:31:12 »
Also check your subframe mounts, which can collapse. (center of the subframe on top). also Check to be sure the motor mounts have stop plates and rubber stops under them. These screw into the motor mounts from underneath and prevent the engine from bouncing up too far.
« Reply #4 on: December 09, 2016, 00:25:23 »
... and check the rear motor mount - the one behind the gear box. Very important too !
A.
« Reply #5 on: December 09, 2016, 09:37:10 »
If you look at the subframe mounts from the engine compartment on the top of the frame rails you shouldn't see the big bolt in the middle of the hole only the 4 small(13mm head) bolt that attach the mount to the chassis.  If you see the big bolt head (22mm head?)  your stop plates are missing.  you might have to remove the black plastic cover first.
ggdtr5
« Reply #6 on: December 09, 2016, 21:43:19 »
I checked my supports -  the left hand one I cannot see any markings however the right hand one has '180' on it.
Looks like I will be looking for the correct supports - thanks for all the advice.
Regards Graham
1971 280 SL
1972 Triumph TR6
1979 mini pick up
1992 Mini Cooper
2002 Honda S2000
2002 Honda S2000
