Author Topic: Steering Wheel Replacement  (Read 2899 times)
gstorek
« on: December 14, 2016, 00:27:23 »
I am replacing the original steering wheel on our '71 280SL, however the main nut holding the wheel to the steering column seems to be frozen tight.  There is even something on the nut that looks like a dab of paint, perhaps applied at the factory.  It looks like its never been touched.  Has anyone had experience on the best way to remove this nut? Is it just a matter of a good long socket wrench for maximum leverage and brute force?  Any advice will be most appreciated.  Thanks!
cabrioletturbo
  • Canada, Ontario, Ottawa
Re: Steering Wheel Replacement
« Reply #1 on: December 14, 2016, 01:01:03 »
Turn it first clockwise slightly while holding the steering wheel, then counter-clockwise to unscrew.
It should work. Green paint is from factory.
Igor
« Reply #2 on: December 14, 2016, 05:06:41 »
I've used an impact gun which will remove it easily.
« Reply #3 on: December 15, 2016, 15:43:07 »
Use a longer handle or impact gun as Dan suggests. Have someone hold the steering wheel while you take the nut loose, so you do not damage the steering lock.
