Author Topic: Speedo inner cable  (Read 4389 times)
cfm65@me.com
  • Cape Town, South Africa
Speedo inner cable
« on: January 01, 2017, 16:20:54 »
Hi Guys,
Compliments of the season.
Please help, is there a difference between the auto and manual speedo cables? I am talking about the common 3mm end of the inner cable which goes into the tranny. I have installed a new cable but the speedo does not work and I checked the top end of the cable does not turn while driving the car.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Speedo inner cable
« Reply #1 on: January 01, 2017, 16:39:15 »
The ends are the same. The length is different. Is it possible the end of the cable wasnt fully seated before you installed the allen pinch bolt? It can be deceiving. The pinch bolt must pass through the concave detent in the cable end. Was it working before the cable was replaced?
cfm65@me.com
« Reply #2 on: January 01, 2017, 17:24:06 »
Hi Tyler,
TKS for your assistance.
No, I got the car without the inner and ,yes, the pinch bolt is in the groove. I was led to believe the tranny was reconditioned a while ago. I sincerely hope the speedo drive was installed and if so, correctly.
Much appreciated. I'll have another look and will report back.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #3 on: January 01, 2017, 18:12:02 »
Put the rear wheels up on jack stands. Put the trans in neutral and rotate one wheel while keeping the other fixed. (You can do this using your feet) Shine a light into the hole and you should see the driven gear end spin.
cfm65@me.com
« Reply #4 on: January 01, 2017, 18:24:37 »
I think you cant see in there on the auto. I had difficulty inserting the cable end and could not quite see what the problem was.  I'll have another look tomorrow, the car was possibly not raised high enough for me to get up close to look directly onto the hole.
I'll let you know what I found, thanks.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
cfm65@me.com
« Reply #5 on: January 02, 2017, 07:45:43 »
Hi Tyler,
I found the inner cable to lean over to one side and would therefor not mate with the drive coupling.  I sharpened the end slightly, made a little kink and lubed the tip. I then ensured that the inner cable was and stayed in the centre, turned the wheel with my foot and voilà
Thank you
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
