Become a
Full Member
Emergency Contact List
Electrical and Instruments
Inhibit switch
Topic: Inhibit switch (Read 4779 times)
cfm65@me.com
Associate Member
Gold
Cape Town, South Africa
Inhibit switch
January 03, 2017, 06:10:05 »
Hi Gents,
This photo of the inhibit switch on my 250SL shows 2 purple wires on the LH of the plug. The one is purple or violet and the other purple with a white tracer. They are about the same length and I cant figure out which one goes into the top position and which in the bottom. I dont think it is all that important BUT it might be.
Your assistance will be much appreciated.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Re: Inhibit switch
January 03, 2017, 07:57:08 »
maybe these pictures can help:
http://www.pagodentreff.de/diskussionsforum/t10752-automatikschalter-2.html
It looks regardless of which position they are. Did you check the function of inhibit function and rear drive light?
...WRe
Last Edit: January 03, 2017, 08:11:07 by WRe
cfm65@me.com
Associate Member
Gold
Re: Inhibit switch
Reply #2 on:
January 03, 2017, 09:01:29 »
Hi WRe,
Thank you for your help.
I am also of the opinion that it will not make any difference, but I wanted to check first.
No, I have not checked the function of the reverse lights, but I'll have a look.
Thank you.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Pagoda SL Board
Platinum
USA, CA, San Marcos
Re: Inhibit switch
Reply #3 on:
January 03, 2017, 17:30:39 »
From the picture it appears the two purple wires have been messed with somewhere in the past. Notice the difference in the way the soldering/connections are made on the other two wires.
Could some other changed connections on those two purple wires be an issue??
cfm65@me.com
Associate Member
Gold
Re: Inhibit switch
Reply #4 on:
January 03, 2017, 17:59:33 »
Could be Jonny,
Could also have been resoldered by a ham fisted handy man. Mine is not a well kept or well maintained speciman. I am trying to pick up the loose ends as best I can.
However, the reverse lights are working correct. I still need to hook up the kick down switch. One step at a time.
Thanks guys your assistance are much appreciated.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
sandcrab59
Full Member
Silver
USA, MA, Lunenburg
Re: Inhibit switch
Reply #5 on:
January 06, 2017, 22:51:56 »
What is a inhibit switch?
I probably know it by another name.
71 280SL-8 Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
Travis71280
Re: Inhibit switch
Reply #6 on:
January 07, 2017, 00:33:05 »
It's the switch on the firewall that prevents the starter from engaging while the car is in gear.
Full Member
Platinum
USA, OH, Blacklick
Re: Inhibit switch
Reply #7 on:
January 07, 2017, 06:43:11 »
These are also known as the neutral safety switch. Depending on the version and year of production, the wire quantities and colors will vary.
Inhibit switch
