Hello, I have a 1966 250SE Coupe that I recently acquired. It is a US model in great unrestored condition. It took a while to get the fuel injection sorted out (timing was 180 degrees out, etc.) and then it started sputtering and died. Thankfully, it had only run out of gas - the gauge was stuck at 3/4 full. I refilled the tank and it was still sputtering so I took it back to the mechanic, who said that he had experienced that before and it was probably debris around the cage that collects fuel at the sending unit. I asked if he could check out the sending unit while he had it out and he said that it was not serviceable. However, he cannot find a replacement since the sender is a 7 inch long unit and not the standard 6 inch model. He said that he has only seen a few of these models and they are rather rare. Has anybody else encountered the 7 inch fuel sender or where to purchase one?
Thanks for any help you can give,
Darren
