Author Topic: Fast idle solenoid  (Read 4285 times)
cfm65@me.com
  • Cape Town, South Africa
Fast idle solenoid
« on: January 14, 2017, 15:43:27 »
Hi Guys,
I believe the 280SL fast idle solenoid has an internal permanent magnet which pulls the plunger back when fast idle is no longer required.
Does the fast idle solenoids fitted to the 230SLs and the early 250SLs have the same magnetic 'pull back' function or was it left to the throttle return springs to do the 'push back'
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Fast idle solenoid
« Reply #1 on: January 15, 2017, 04:25:55 »
I don't think it's a two way solenoid and that it only pushes out. I believe that the throttle linkage return springs should provide enough tension to retract it after activation.
cfm65@me.com
« Reply #2 on: January 15, 2017, 06:55:47 »
TKS Doc,
Yes, mine is also like that(pushed back by the return springs in the system)
However, I thought the later models had a permanent magnet to assist in the 'pull back'.
With the slop in my early 250SL system, a pull back magnet will make life a lot easier.
Any further comments will be much appreciated.
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #3 on: January 15, 2017, 21:04:11 »
The really late version uses a vacuum controlled throttle body and the CSS is deleted.
cfm65@me.com
« Reply #4 on: January 16, 2017, 04:52:31 »
TKS Doc,
Much appreciated.
Have a great week.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
