Author Topic: 3 small holes in inner mudguard, near brake fluid reservoir  (Read 3256 times)
PIP1947
Can anyone advise me as to the intended purpose of the three small holes in the right inner guard of my '68 280SL, immediately behind the brake fluid reservoir. I can see no evidence of a previous bracket or attachment, but the holes are clearly visible from within both the engine bay and mudguard. Photos attached. Thanks in advance for any assistance.
Pip1947
cfm65@me.com
  • Cape Town, South Africa
Re: 3 small holes in inner mudguard, near brake fluid reservoir
« Reply #1 on: January 15, 2017, 14:40:48 »
Hi Pip,
The metal is shaped in a distict little landing or mound and the Lefies have a relay mounted on that little mound. I cant remember which relay, but someone will pipe up with the answer. It could also be the voltage regulator.
Yours being a later model could have an alternator with a built in regulator, hence the omission of a VG.
In the mean time I'll see if I can make out which (relay or VG) it is.
Regards
Chris
Cape Town
« Last Edit: January 15, 2017, 14:52:17 by cfm65@me.com »
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: January 15, 2017, 15:51:37 »
Indeed it is for a bracket that mounts the voltage regulator and small fusebox for radio (if applicable). LHD
PIP1947
« Reply #3 on: January 17, 2017, 04:52:36 »
Thanks to  Chris and Tyler for enlightening me. The thought did cross my mind but I dismissed it, thinking MB would be unlikely to leave three potential sources of corrosion naked and unfilled. Now I can ignore them. Cheers.
Pip1947
