Author Topic: D.C. Magnet  (Read 3465 times)
mBdrvr
  • USA, PA, Bethlehem
D.C. Magnet
« on: January 18, 2017, 04:59:17 »
I'm reinstalling the D.C. Magnet in the car and tested it to be sure it works.
When 12 volts is applied to it, it extends but does not retract when power is removed.
Is this the way it was designed or is it defective?
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
cfm65@me.com
  • Cape Town, South Africa
Re: D.C. Magnet
« Reply #1 on: January 18, 2017, 21:01:30 »
Which DC magnet are you refering to?
I am not sure what you are talking about. Is this perhaps the one mounted on top of the inlet manifold, the one called the fast idle solenoid? The one that extends in order to increase the idle speed when selecting drive or reverse?
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
mBdrvr
Re: D.C. Magnet
« Reply #2 on: January 18, 2017, 23:07:37 »
Yes that's it. The parts book calls it a D.C. Magnet.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Re: D.C. Magnet
« Reply #3 on: January 18, 2017, 23:34:37 »
That's how they work. Return springs on the throttle linkage should pull it back into place.
 I've had cases where the CSS wouldn't return properly and the only way that I was able to fix this problem was to replace all of the ball studs and throttle caps on the linkage. Once everything is tight it will work perfectly.
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Re: D.C. Magnet
« Reply #4 on: January 19, 2017, 01:08:54 »
mBdrvr
Re: D.C. Magnet
« Reply #5 on: January 19, 2017, 18:34:34 »
Thanks all for the confirmation.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
