Author Topic: Instrumental Light  (Read 4609 times)
spumarola
Instrumental Light
« on: January 25, 2017, 15:58:03 »
Interior instrumental dashboard lights not working. How can I fix it? Maybe it's the light bulb.
WRe
Re: Instrumental Light
« Reply #1 on: January 25, 2017, 17:28:28 »
it seems unlikely that all dashboard bulbs (2+7+2) failed at the same time. It should be another fault: fuse or rheostat/dimmer. In most cases it's the dimmer. Can you turn/move it? Sometimes this also causes a burned fuse. Most of us installed a dimmer by-pass because the dimmer ist more or less useless.
...WRe
Jordan
  • Canada, ON, Jordan
« Reply #2 on: January 25, 2017, 18:07:23 »
And don't forget to check the fuse, it's number 7 I believe.
Marcus
66 230SL  Euro 4 speed
PIP1947
« Reply #3 on: January 26, 2017, 09:11:41 »
Hi all. I have the same problem and would prefer to simply by pass the rheostat. Can anyone point me to a more detailed thread on the subject, with photos, wire colours etc? Regards
Pip1947
kampala
  • USA, CA, Hermosa Beach
« Reply #4 on: January 26, 2017, 09:37:55 »
How about checking our very own amazing Tech Manual:
https://www.sl113.org/wiki/Electrical/Rheostat
Really well described by whomever took a lot of time to put this in the manual.   Great info here.  Go to the bottom if you just want to bypass and not repair.
250sl - later - manual
280sl - 1971 - Auto - LSD
