Author Topic: Venturi control/ warm water ring orientation  (Read 2371 times)
cfm65@me.com
  • Cape Town, South Africa
« on: February 05, 2017, 05:38:30 »
Hi Gents,
Between the ventury control and air filter hose, is a hot water sleeve/ring which is slightly angled.
Is this sleeve all side, same side and should it be angle to the rear or forward?
As can be seen in the foto, mine is angled to the rear and therefor interfering with full throttle movement.
Should the sleeve/ring be turned around, (kink forward) or should it be turned slightly down, not to interfere with the throttle movement?
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Venturi control/ warm water ring orientation
« Reply #1 on: February 05, 2017, 06:02:55 »
Chris, It is installed correctly. The "kink" goes twards the rear of the car. You can loosen both clamps and twist it clockwise/down a bit to keep the throttle linkage ball socket from hitting it.
Just an observaton, it appears your throttle return spring is missing.
cfm65@me.com
« Reply #2 on: February 05, 2017, 09:34:48 »
TKS Tyler,
Much appreciated and yep, I only have a spring on pedal side. I'll put one on the business end as well.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
