Author Topic: How do I remove the rear view mirror?  (Read 3130 times)
CJHenderson
  • USA, AR, Benton
« on: February 08, 2017, 17:00:02 »
How do I remove the rear view mirror? I have everything removed from the windshield frame and cannot see how the mirror is attached.
1950 MG-TD
  • USA, WI, Mequon
Re: How do I remove the rear view mirror?
« Reply #1 on: February 08, 2017, 17:21:08 »
just pull on the neck toward you.  It snaps on and off.
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: February 08, 2017, 17:35:02 »
The mirror is held in position by special clips, as a sefety feature and will 'break' loose in the event of a accident. It then clips back in pisition.
The base is held onto the window frame by two screws.
Pull it off by hand as in my  photo. Carefully pull it towards you.
Regards
Chris
Apologies, my photo arrive at 90 degrees
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
CJHenderson
  • USA, AR, Benton
« Reply #3 on: February 08, 2017, 17:49:57 »
Thanks for the way to do it.
1950 MG-TD
CJHenderson
  • USA, AR, Benton
« Reply #4 on: February 08, 2017, 17:51:05 »
Thanks for the photos I'm going to use them along with my photos when I start rebuild.
1950 MG-TD
