Author Topic: Front hub removal  (Read 3350 times)
RonDwyer
Front hub removal
« on: February 13, 2017, 01:47:30 »
The oil leaking was enough to warrant fixing before I drive this to San Jose next weekend for a thorough steam cleaning.  I was amazed at how easily the front bolt was to remove from the crankshaft.  Doing this with anything less than a 1/2" drive with extension and using the bumper as a support would have been impossible.  Amazing how easy it is to get at all the rest of the pieces with everything removed  :)
The extra pipe on the ratchet made this the easiest removal.
Not sure if the designers at MBZ put that hole in the harmonic to be used like I did, but it sure did make the job easier.
Re: Front hub removal
« Reply #1 on: February 13, 2017, 03:54:30 »
When I worked in a European car shop we used to put a breaker bar against the frame rail and hit the starter.
RonDwyer
« Reply #2 on: February 13, 2017, 04:07:43 »
I have a preference for solutions that are a little less stressful on cast iron components after watching a friend break the nose off his M30 BMW crankshaft using a 3/4 drive impact.  Even with a 36" pipe on the end of a 24" ratchet this afternoon, all it needs is a little force to get the first crack, then you know it is good to go.  The starter method sounds like a great way to ruin the ring gear.   That bolt has not been off the car since 1969. glad I thought to use a little Kroil on it.
« Reply #3 on: February 13, 2017, 05:40:29 »
Good tip Pat.  I'm sure the ring gear is robust enough to take the stress.
Kevkeller
  • USA, HI, Honolulu
« Reply #4 on: February 13, 2017, 12:55:34 »
I used a impact wrench and the bolt came off very easily.  It took a few seconds for it to start moving but it did work.  I guess the nice thing about this method is you don't have to hook up anything to stop the engine.
Has anyone heard of a reason not to use this method on the W113's?  notwithstanding what Ron said?
Kevin
1970 280 SL
mbzse
« Reply #5 on: February 13, 2017, 13:10:14 »
Quote from: RonDwyer
.../...Not sure if the designers at MBZ put that hole in the harmonic to be used like I did, but it sure did make the job easier.../..
That hole in the harmonic dampener is there so that the lower bolt for the water pump housing can be loosened/tightened.
You found new ways for using it, I see he he
/Hans S
RonDwyer
« Reply #6 on: February 15, 2017, 02:44:30 »
And who wouldn't take advantage of a convenient hole in time of need?  :o
