Author Topic: Can you resolve this hood puzzle?  (Read 2797 times)
kiheimatt
« on: February 18, 2017, 20:04:17 »
I came across a hood that looks pretty straight, but someone had run a tig bead around the entire perimeter.
Any guesses or explanations for this?
DaveB
Re: Can you resolve this hood puzzle?
« Reply #1 on: February 18, 2017, 21:46:43 »
Original hoods were built slightly oversize and hand-filed to fit each car. When a hood is transferred onto another car it will need some building and filing to get a correct gap all round. So this hood has perhaps been prepped for another car but not installed.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #2 on: February 18, 2017, 22:06:44 »
Hoods are made in two pieces and then they're spot welded together around the entire outer edge. Sometimes the two halves will start to separate around the nose area and welding is required to repair this area. I see no reason to weld all the way around the outside unless it really needs it, which I doubt.
dirkbalter
  • USA, CA, Corona
« Reply #3 on: February 19, 2017, 00:26:13 »
I had to do a similar thing to the front edge of my hood. The gap to my front mask was approx. 15 mm after all the paint and bondo was removed.
If the welding that was done is good, you should be happy as it is a lot easier to trim it back to a perfect gap instead of adding material.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
