Author Topic: Throttle return spring  (Read 2709 times)
alpina
  • Spain, Asturias, Villaviciosa
« on: March 12, 2017, 22:23:36 »
The BBB shows The throttle return spring (26) connected to the regulating shaft using the
Inner / hole closest to the firewall. However I cannot find anywhere showing which hole should be used on the metal bracket attached to the firewall. Is it also the one closest to the firewall? Or is it not important?
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
Re: Throttle return spring
« Reply #1 on: March 13, 2017, 01:07:39 »
On my car there is only one hole in the lever and only one in the bracket on the firewall. Therefore, you doe not have "Die Qual der Wahl"
« Reply #2 on: March 13, 2017, 05:14:19 »
Hole position will effect accelerator pedal pressure needed. I would start off with the one closest to the firewall. As long as all your linkages and accel. pedal return to idle stop, you should be fine. Use the outer hole if you need more force to return everything to idle stop.
