with our official
Pagoda SL Group logo
from our official partner.
Center bearing
Topic: Center bearing (Read 2220 times)
reg
Full Member
Junior Level
Canada, BC, Victoria
Center bearing
March 22, 2017, 23:22:34 »
I need help. Have my drive shaft out but do not want to break this aluminum housing. What do I need to do to get this off and put in the new bearing. This is a 1966 230sl auto. Thanks in advance as I don't post very often
Last Edit: March 23, 2017, 03:13:34 by reg
Vendor
Platinum
Canada, ON, Port Lambton
Re: Center bearing
March 23, 2017, 17:08:13 »
Did you mark everything before you took it apart? The drive shaft is balanced and should be assembled in the same way it came apart.
Isn't there a snap ring that holds the bearing in place?
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
reg
Full Member
Junior Level
Re: Center bearing
Reply #2 on:
March 23, 2017, 17:25:23 »
thanks for the info just need a better puller all should be fine and I did mark everything so it should go smoothly.. have been chasing this noise for awhile
Center bearing
