If you wont be doing much to the underneath of the car, then find a setup that uses the factory weigh points (front subframe anchor and rear axle points). This way you will be unobstructed to do body work and paint on the front and rear of the car. You shouldnt need door jamb stiffeners if the chassis, floors and rockers are sound.
