Author Topic: Rear of Car low  (Read 3839 times)
Markbhai
Rear of Car low
« on: March 31, 2017, 22:44:04 »
Hi All.
The rear of my car is very low, it looks like something might have collapsed.  I have popped it up on axel stands and had a look underneath and all of the springs seem to be in tact in thier mounts, which also appear OK.
The rear differential is covered in fresh oil, so I am wondering if this might be a clue to the problem.
Any ideas?
Mark.
Re: Rear of Car low
« Reply #1 on: April 01, 2017, 04:28:02 »
Did someone put a hydro-pneumatic compensator on your car instead of a compensator spring?  If so your hydro-pneumatic compensator has failed.
Markbhai
Re: Rear of Car low
« Reply #2 on: April 01, 2017, 06:21:37 »
I will see if I can get a photo.
I would have done so yesterday but the phone died!
Mark.
Re: Rear of Car low
« Reply #3 on: April 01, 2017, 15:25:27 »
Check the center diff mount in the trunk under the plastic cover. If it has colapsed it will let the differential swing down and in effect let the hubs pivot up. There should be a noticable gap between the large upper dished washer and the mount.
« Last Edit: April 01, 2017, 17:06:35 by Tyler S. »
WRe
Re: Rear of Car low
« Reply #4 on: April 01, 2017, 16:29:59 »
here you'll find info and pics about a Boge hydromat and a low rear of our cars: http://w113.eu/geschlossen/Optimierungen/Hydromat%20in%20eine%20Mercedes%20Pagode%20W113%20einbauen.htm.
...WRe
Markbhai
Re: Rear of Car low
« Reply #5 on: April 01, 2017, 23:54:20 »
Thanks guys.
I dont think the car has the Hydromat fitted (I am 90% sure there is a spring in that position), so I suspect the cente bush could be at fault.  The car is garaged and I am not likely to get to it until next weekend.
Just so that I know what to look for does anyone have any advice/pictures of what I should see for the centre diff mount?
The car is up on axle stands with wheels off he ground, the wheels are pivotted at a strange angle in this position, possibly backing up this theory.  I assume with the car in this position the centre mount wont be pushed up? - What do I look for to see if it is collapsed?
I can get a jack under the axle if this will help to diagnose?
Mark.
« Last Edit: April 02, 2017, 00:13:01 by Markbhai »
Re: Rear of Car low
« Reply #6 on: April 02, 2017, 00:20:20 »
Mike K
    • Mike Kirkinis
Re: Rear of Car low
« Reply #7 on: April 02, 2017, 21:13:45 »
I also undertook that job some months ago, here's my write up with some images as well:
https://www.sl113.org/forums/index.php?topic=25089.msg179351#msg179351
You mentioned that you've checked the springs in their mounts. Have you checked the condition of the rubbers which are mounted on the top of the rear springs?
You also mention the presence of oil, have you checked your shock absorbers?
Mike
« Last Edit: April 03, 2017, 07:16:34 by Mike K »
http://michali.zenfolio.com
