Author Topic: 280 Late block early head....  (Read 2221 times)
erickmarciano
  • Canada, Quebec, montreal
« on: April 07, 2017, 03:58:28 »
Hi guys . I am trying to help a friend remotely . He is telling me he has a late 280sl block with a early head . Car does runs lean no mater what we do
Would the car run with this nissmatch?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: 280 Late block early head....
« Reply #1 on: April 07, 2017, 05:30:39 »
No. I ended up with the wrong head gasket set once on an early engine ( late head set ) and it burned through the gasket filling the crank case full of coolant. I can't imagine you would want to try it and find out the hard way.  Just sayin'.
« Reply #2 on: April 07, 2017, 05:54:07 »
The early head will not work on the late block and vice versa. A bad barometric compensator can cause a permanent "lean" condition. Low fuel pressure can also cause lean running.
