Author Topic: 1969 w111 280 electric sunroof problem  (Read 6754 times)
rockingchairmotors
  • USA, PA, Coplay
  • 1-610-972-9694
« on: April 09, 2017, 15:17:05 »
Hello
I have a 69 W111 280 with an electric sunroof.  I am having a problem getting the roof to close completely.
I know the W108/109 sedans have a place in the trunk to manually close the roof.  I also have the tool from a sedan to do it.
Does the coupe have a place to close the electrical roof manually?  I have nothing in the trunk.  Where is the manual mechanism located?
Thanks in advance
Jeff
Re: 1969 w111 280 electric sunroof problem
« Reply #1 on: April 10, 2017, 07:34:51 »
You should have a sun roof motor in the trunk.  The place to fit the tool should be on the drive gear box at the electric motor.
rockingchairmotors
  • USA, PA, Coplay
  • 1-610-972-9694
« Reply #2 on: October 28, 2018, 12:59:31 »
I am starting to work on this car.
Did they ever put the sunroof motor behind the rear view mirror, in the roof compartment?   My car is a low grill 280 and that is where the motor is located.  I have never seen it there in any other car?
I also do not have the emergency closing mechanism in the trunk.
I will try and post a few pictures. Thanks for the help
« Reply #3 on: November 07, 2018, 01:55:23 »
Quote
Huh? :o ??? ???
Aftermarket non-original-MB sunroof  ?
Strange....
(electrical factory-original Webasto sunroof in his W114 with motor in trunk)
Desertpagoda
  • USA, AZ, Tucson
« Reply #4 on: August 15, 2020, 17:16:32 »
yes, aftermarket
kb
austinado16
« Reply #5 on: August 16, 2020, 01:06:37 »
Aftermarket?  Wow.....please post photos.
My suggestion would be to open the roof full, and then either put something down and stand on the seats up through the open roof, or protect the body of the car (roll the door glass up and trap a heavy moving blanket so it hangs down the door) and use a ladder.  With the roof open, inspect the left and right tracks for debris, and damage.  If there is some sort of wind deflector that pops up at the front of the roof opening, make sure that how ever it springs up, and is pushed down by the closing roof, is all functional, not broken, and not got debris stuck in it.
From outside the roof/body (in other words, not stand up through the sunroof opening, close the roof slowly and watch what it's attempting to do as it gets nearly closed.
Typically a sliding roof will push down a wind deflector as it moves forward that final couple of inches (our factor roofs have no deflector), and then at the rear of the roof there is some sort of lifting mechanism or a ramp on each side, that raises the rear of the roof up, and flush with the car's roof.  Issues in these 2 areas will keep the roof from closing fully.
Some people will park a car with the roof either fully, or partially open, and then tree debris will fall into areas of the rails.  This debris may not affect the roof right away, but eventually will, and since it's a behavior that the owner has, they will keep leaving the roof open, allowing more and more debris to fall into the roof.  So that's why your first check is always for debris, and old grease that has become dry, and almost like clay.
