Author Topic: 220se no reverse ?  (Read 5097 times)
Pagoda55
220se no reverse ?
« on: April 11, 2017, 16:57:16 »
Hi all a friends 220se auto gearbox just stop working in reverse but has all the forward gears 2,3,4d ,N ,park any ideas thanks ,the fitter  and fluid was changed  2 thousand miles ago  :o
drmb
  • New Zealand, Waikato, Te Awamutu
Re: 220se no reverse ?
« Reply #1 on: April 11, 2017, 18:56:28 »
Most common fault is the pin for the pivot for the reverse band sheers off.
You need to remove the pan then the pin can be removed from the bottom of the main housing.
Mercedes Restorer.
1969 280sl 050 whte Blue interior
1996 E320 Cabrio
1963 220se 111-023 cabrio, red,black interior.
1967 Morris Cooper
Lloydmarx@xtra.co.nz
« Reply #2 on: April 12, 2017, 07:30:33 »
Often times the reverse band adjustment lock nut comes loose allowing the band adjustment to back off.  If this is the case, turn the 10mm reverse band in until snug, then back it off about 1 3/4 turns. Lock the adjustment with the 22mm nut. All is accessible from below. Don't forget to check the fluid level also!
Pagoda55
« Reply #3 on: April 14, 2017, 23:41:22 »
Hi ,thanks guys I'll pass the info on
