Author Topic: quarter window rubber seals  (Read 3176 times)
vegimite
« on: April 13, 2017, 11:28:36 »
I am replacing the rubber seals on my hardtop quarter windows and unfortunately I lost my disassembly photos so I don't know which way the rubber sits on the glass. (ie which is the out facing side of the rubber)  would anyone have a good close up photo to help??
cheers............Paul
EdwardBernard
  • Canada, AB, Edmonton
Re: quarter window rubber seals
« Reply #1 on: April 18, 2017, 22:33:46 »
Hi, I have no photo, but when you look at the rubber seal, on one side there are lips cut along the lengths that will overlap the outside window chrome pieces. You can carefully run your fingernail or a pen point down the length of the overlap lips.
Bill Leddy, Edmonton, AB, Canada
1964 230 SL, red, manual, ps
rutger kohler
« Reply #2 on: April 20, 2017, 23:04:05 »
Hi, several years ago I forwarded a copy of the MB setup to remove and replace these, to the website. It was cleaned up by Peter E and put into the onboard technical manual somewhere.  Should still be there
cheers
Ruger Kohler
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
« Reply #3 on: April 21, 2017, 07:21:44 »
The PDF in the Tech Manual how to replace the windows
https://www.sl113.org/wiki/uploads/Tops/SL%20Hardtop%20Sidewindows.pdf
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
vegimite
« Reply #4 on: February 10, 2018, 03:18:38 »
Thanks folks I managed to nut it all out.   late reply as I have not been on this site for a long time.  restoring a BMW E9 now..............Paul
