Please check out joining the
Emergency Contact List
for help during your travels!
W11x chassis cars
W111 1969 2.8 l fuel pump problem
Topic: W111 1969 2.8 l fuel pump problem (Read 4664 times)
symonb
April 18, 2017, 21:56:31 »
Hi. My 1969 280se 2.8 cabrio long fuel pump has packed up.
Can anyone please advise as to where I could get the flow rate and pressure measurements for this pump. (or where I could get a replacement)
I am really struggling on both counts. Many thanks.
m300cab
Associate Member
Silver
USA, Pennington New Jersey
Re: W111 1969 2.8 l fuel pump problem
May 10, 2017, 23:56:05 »
i don't have the info you requested but
you should check the screen inside the pump, sometimes they get clogged
there's a fuel tank filter, fuel pump filter (inside intake nozzle)
, and fuel injector filter under the hood
Michael Parlato
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
May 11, 2017, 04:27:46 »
You need about 10 PSI and 1 liter in 15 seconds for the pump to be considered a good unit. Check fuel pressure at the CSV fitting and fuel volume after the fuel damper where the line runs back to the fuel tank. If all of these things check out, test the return fuel line running to the tank with compressed air to see if anything is blocked. Remove the gas cap first and put a rag around your air wand to prevent blow back into your face.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
W11x chassis cars
