Author Topic: Fuel filter torque spec-280SL  (Read 2393 times)
stevesoz
« on: April 21, 2017, 18:16:56 »
Replacing the original(brass) fuel filter with the OEM replacement(aluminum) and wondering what the torque specs for tightening are.
Re: Fuel filter torque spec-280SL
« Reply #1 on: April 21, 2017, 18:18:20 »
None that I'm aware of. If it leaks, it's not tight enough.
stevesoz
« Reply #2 on: April 21, 2017, 18:22:34 »
Pretty easy to over tighten aluminum threads and have them strip out!
« Reply #3 on: April 21, 2017, 20:18:11 »
I think the pipe inside the housing is steel so it shouldn't strip the threads. Fuel will leak out of a very small opening and that's why you might need to keep tightening until it stops leaking.
