Have removed the glass and attached the rear guide that was missing from the glass and reattached the front guide that was wedged in place with black electrical tape?? Both of these pieces were re-attached with "thin felt" and epoxy.
Would like to replace both of the window whiskers. The inner whisker was easily removed however the outer whisker removal procedure is not nearly as obvious.
Any help with providing the best procedure to remove the outer whisker would be appreciated.
