Author Topic: constant power to hazard switch?  (Read 7274 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« on: May 03, 2017, 15:01:53 »
So I have turn signals but no hazards lights.  I took apart the hazard switch and it seems to be ok.  But shouldn't the one hot input ALWAYS have juice?  The hazards should work with or without the key in right? So using that logic one of those 6 pins that go to the hazard switch should ALWAYS have juice.  Before I get deeper into the wiring I figure I would bounce this logic off the experts here.
Bob "Baron" Youngman
1965 220se coupe restomod
Re: constant power to hazard switch?
« Reply #1 on: May 03, 2017, 15:32:48 »
Just went to the garage to check my 1970 280 SL, and indeed the flashers work with the key out.
Montreal V8
« Reply #2 on: May 03, 2017, 16:58:28 »
 Hi Bob. The live feed comes from fuse #1. For some reason, the wiring diagram does not give the color codes, but it may be white/slate (gray), but this is only a guess.    Cheers,    Dale.
mbzse
« Reply #3 on: May 03, 2017, 17:11:50 »
Quote from: Dale
.../... For some reason, the wiring diagram does not give the color codes.../...
High-class colour coded wiring diagrams for our W113 cars is part of full membership on this website.
See https://www.sl113.org/wiki/About/Membership for details on how to join!
/Hans S
Montreal V8
« Reply #4 on: May 03, 2017, 17:55:00 »
Thanks Hans. I missed going to the color diagrams. The wire appears to be Red with black/white tracer - so much for my "guess".      Cheers,   Dale.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #5 on: May 03, 2017, 21:36:57 »
What # on the color diagram  is the Hazard switch?
« Reply #6 on: May 04, 2017, 00:28:09 »
Bob, on the Aug 1970 diagram, the hazard switch/relay is item #18
Montreal V8
« Reply #7 on: May 04, 2017, 00:33:58 »
Hi Bob. It's #18,  and I misled you, as the wire color is red with a white tracer  -   this old age thing is a curse !!      Cheers,   Dale.
  PS.   As I was writing this, I  see Tyler already updated you.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #8 on: May 04, 2017, 14:25:05 »
so new wrinkle... with hazard in off position the turn signals work, with it in the on (pulled out) position the turn signals do not work and the hazards still  do not work.  I see am going to have a long evening of tracing down wires.
« Reply #9 on: May 04, 2017, 14:48:06 »
Bob, the turn signals not working when the hazard switch is pulled is normal. The hazard switch electrically disconnects the turn signal combination switch when activated. Keep your focus on making sure the hazard switch has power with key off.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #10 on: May 15, 2017, 15:33:25 »
So I am still trying to find out why I am getting no power to the hazard switch, so I decided to make sure everything else is working and I got to the horns that I need to install, with the key in the on position both horn wires (one on each horn) have juice.  It is my understanding from the tech manual that these run in parallel so it is ok that these have juice all the time the key is in on position or the car is running.   If I understand correctly when I hook the horns up then it will require the horn to be depressed  to ground and complete the circuit.  This all sound correct?
« Last Edit: May 15, 2017, 17:17:21 by BaronYoungman »
« Reply #11 on: May 15, 2017, 17:28:47 »
that is how the horns are wired to fuse #2 according to the wiring diagram. As a full member you have access to it. Take a look, the horns are number 11:
https://www.sl113.org/wiki/uploads/Restricted/280sl.jpg
« Reply #12 on: May 19, 2017, 13:50:54 »
Hello Bob,
Sounds weird. ???
Perhaps one or two of the wires in the plug have been mixed up during assembly?
Or your Bosch 0 335 240 002 relay is not more working properly.
Have you checked with a spare relay?
Good luck
(colored wiring diagram ilustrator)
