Author Topic: Power steering belt tension bolt  (Read 8962 times)
dldubois
  • USA, FL, Pembroke Pines
« on: May 03, 2017, 18:47:12 »
Anyone know where to get the tension bolt?   It's a dang bolt and its still over $100 from the classic center.
Dana DuBois
1969 280sl
Pembroke Pines, FL
Re: Power steering belt tension bolt
« Reply #1 on: May 04, 2017, 01:32:43 »
A little better in price but you would need to research the shipping cost.
http://www.theslshop.com/mercedes-benz-w113-pagoda-sl-230-tensioning-bolt-for-pas-mounting-bracket.html
« Reply #2 on: May 04, 2017, 03:23:17 »
You could make one by using a 6mm screw and welding a washer to the end of it. The part in question is little more than that.
dldubois
« Reply #3 on: May 05, 2017, 00:07:21 »
Thanks Tyler.   With shipping that's just over $42.    A lot better than $120 from the classic center.   Just got to confirm its the same on the 230 vs 280sl
Dana DuBois
1969 280sl
Pembroke Pines, FL
dldubois
« Reply #4 on: May 08, 2017, 13:24:45 »
Do you all know if the part is the same on all 113s?    The SL shop has it but says it for a 113 through 1967.   I've got a 69 SL.    I'm trying to get ordered but seem to be confusing them as they don't seem to understand what I'm talking about via email.
Dana DuBois
1969 280sl
Pembroke Pines, FL
Val
« Reply #5 on: May 08, 2017, 16:27:18 »
SLS in Germany only show one part number for the bolt. They are normally pretty accurate.
http://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/46-steering/46-d-steering-gearbox-fluid-pump
« Reply #6 on: May 08, 2017, 22:53:51 »
Yes,
this has also been my understanding so far that the parts are identical.
At least they look identical on my '64 SL and the 1971 sedan. :D
I'll chekc back with the EPC.
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
« Reply #7 on: May 08, 2017, 23:46:22 »
come on guys! You can make one! A file, a vise and a welder. Go to your local blacksmith if you can't handle it. It's not worth your time to order it from the stealer.
« Reply #8 on: May 09, 2017, 05:07:05 »
Or buy this and grind the head width down.
https://www.mcmaster.com/#3800k17/=17jnoj8
« Reply #9 on: May 09, 2017, 20:04:21 »
You do not have to use M6 (metric thread). 1/4-20 threaded rod works just fine but use a 14-20 nut
dldubois
« Reply #10 on: May 10, 2017, 14:32:27 »
I will be creating shortly.    stay tuned
Dana DuBois
1969 280sl
Pembroke Pines, FL
« Reply #11 on: May 11, 2017, 01:59:39 »
Quote
Nonsense. :o
Must be metric, no inch stuff on MB passenger cars, please. >:(
Highly non-original and value diminishing. Don't do that. :-X
If you want, I make you one of metric leftovers I have in my garage.
Just takes a bit,   being extremely slow . :D
Let me have your address though - via PN
(welds sometimes ...)
« Reply #12 on: May 11, 2017, 03:15:57 »
Nonsense. :o
Oh oh, Achim, hold your horses .. or should I write "get off your horse"?!  ;)
The power steering pump was made by Vickers and as Larry once typed:
"The pump was made by Vickers in the UK and the only imperial bolts in the whole car are the 4 which hold the two halves of the pump together, .."
https://www.sl113.org/forums/index.php?topic=13008.msg89097#msg89097
Thus, having a fifth part that is part of the PS pump set-up and not metric wont diminish the value the slightest bit.
mbzse
« Reply #13 on: May 11, 2017, 08:45:03 »
Quote from: 66andBlue
.../...The power steering pump was made by Vickers and as Larry once typed:
"The pump was made by Vickers in the UK.../...
Yes, right...   Just to add some more facts to this, it was designed by Vickers Inc. pump company in Detroit, USA (had nothing whatever to do with the UK Vickers company in Sheffield), and manufactured (as we see on the plate on the pumps) in a Vickers Inc. plant in BadHomburg, Germany
See this old posting:
https://www.sl113.org/forums/index.php?topic=12850.0
« Last Edit: May 11, 2017, 08:57:25 by mbzse »
/Hans S
« Reply #14 on: May 11, 2017, 15:16:02 »
Thanks for the link, Hans!
I knew we had this discussion before but I could not find the thread when I searched yesterday.
« Reply #15 on: May 11, 2017, 19:36:05 »
As I can recall (and my memory is the second thing that went) the washer is oblong with a 6 mm hole and spot-welded to the squished portion of the shank of the threaded rod but the rod has no threads where the washer is welded to it. You should engrave the MB part number on the un-threaded portion. It can be very small so that I could not see it with my diminished vision.
« Reply #16 on: May 11, 2017, 22:18:19 »
Dana,
no, there were at least two different parts.
On a 230SL the power steering pump was p/n 127 460 05 80 and it came with clamping screw p/n 180 466 00 74.
Later on (unfortunately I don't know when) the pump became p/n 127 460 12 80 and the clamping screw p/n 180 466 01 74.
In any case the part was also used as a tensioner for the alternator on Finntails.
I believe ( = not sure!) the earlier clamping screw was a bit shorter and perhaps skinnier than the later one.
Here is a photo of the later screw.
« Last Edit: May 11, 2017, 23:31:47 by 66andBlue »
dldubois
« Reply #17 on: May 18, 2017, 21:59:41 »
The one available was 180 466 01 74 which would be the later version.    I found it for $40 US including shipping versus the $100+ at the classic center.   We will remain original.
Dana DuBois
1969 280sl
Pembroke Pines, FL
