Author Topic: Taillight Assembly Question  (Read 4516 times)
mgpcpa
« on: May 09, 2017, 18:32:59 »
On my '71 280SL, one of the threaded studs and the corresponding round plastic "nut" that tightens down the left taillight assembly in the trunk is missing. As a result, the lights on the driver's side are slightly dimmer, since some of the light is leaking into the trunk. Hopefully these parts are available and, if so, what are the part numbers?
From suburban Philadelphia
johnm
  • Canada, NS, Lawrencetown
Re: Taillight Assembly Question
« Reply #1 on: May 09, 2017, 23:00:35 »
 I purchased metric threaded studs from a local hardware store. You should be able to purchase a corresponding nut to get you by until you find an original or purchase from MB. Good luck...John
1966 250S
Paul & Dolly
  • i Car
« Reply #2 on: May 10, 2017, 07:48:12 »
mgpcpa
Have a look on SLS, you can see most parts there, you can choose German or English on the site.
http://www.sls-hh-shop.de/main/de
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
mgpcpa
« Reply #3 on: May 13, 2017, 17:42:18 »
Thanks, Paul. The website shows the "knurled nut," but none are available.
Cheers, Marshall
Delvis
  • Canada, British Columbia, Delta
« Reply #4 on: June 10, 2017, 05:08:32 »
hello, mgpcpa,
i rarely visit this section of the forum, see attached picture for the knurled nut i just purchased directly from local Mercedes-Benz dealer. fits my 1970 w113 280sl perfect. hope this helps a little. as you know there are 2 per side. i am fortunate that the threaded posts are still in good shape.
Devlin.
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
cfm65@me.com
  • Cape Town, South Africa
« Reply #5 on: June 10, 2017, 05:48:37 »
MGPCPA,
It could be a duff globe.
Pinch a knurled nut from the RH side and confirm that the light leaking out is definately your problem.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
tel76
« Reply #6 on: June 10, 2017, 07:45:03 »
If you want an original plastic nut I have several, PM me your address and I will send you one.
Eric
