Author Topic: diff noise  (Read 3159 times)
reg
  • Canada, BC, Victoria
diff noise
« on: May 11, 2017, 23:43:15 »
Looking for some input,  Am having a differential noise that sounds like a pinion bearing.   I just replaced the drive shaft center bearing and that help a little.   Hoping for ideas as to the cause and possible remedies.   The car is a 1966 230sl
DaveB
Re: diff noise
« Reply #1 on: May 12, 2017, 06:02:16 »
I guess you have already tried it but can you get any movement pushing on the yoke? It should be all solid.
DaveB
'65 US 230sl 4-speed, DB190
reg
Re: diff noise
« Reply #2 on: May 14, 2017, 20:22:44 »
Thanks for the input   am going to check on the condition of all my bushings first.  Maybe I missed one and the noise is just transferring to the body.
DaveB
Re: diff noise
« Reply #3 on: May 14, 2017, 21:38:39 »
Yes if that central rubber mount in the trunk is bad you might get metal to metal contact.
DaveB
Re: diff noise
« Reply #4 on: May 14, 2017, 22:46:36 »
When are you hearing noise? While driving under load, under no load, or while coasting? Each one of these conditions often means you have a different problem to fix. Noisy rear axles are often best fixed with a replacement axle. They're not easy to repair, time consuming to R & R, and repairs will not always be successful.
