Author Topic: Door seals  (Read 2812 times)
philmas
  • France, Ile-de-France, Le Raincy
Door seals
« on: May 16, 2017, 13:31:04 »
Hello everybody!
The inferior door seal on the passenger side has come loose, but the seal itself is OK; it just looks as if it doesn't stick anymore to the door itself.
Is it originally   glued directly on the metal ? If so, what kind of glue would you suggest I should put on it?
Thanks in advance
Philippe from Paris
Euro '71 280SL manual 4sp
Re: Door seals
« Reply #1 on: May 16, 2017, 15:28:28 »
The super duper goo from MB is part no A000 989 92 71. This stuff comes in a can of 12 oz.
3M also makes a weatherstrip adhesive - 08011
When you go to the job, make sure the rubber and the surface are completely clean.
TJMart
  • USA, NC, Matthews
Re: Door seals
« Reply #2 on: May 16, 2017, 15:37:05 »
3M also makes an excellent adhesive remover..
Tony
1970 280SL, 4 Speed
philmas
Re: Door seals
« Reply #3 on: May 18, 2017, 16:45:47 »
Thank you again, I'll see what I can find here, maybe the 3M stuff... :)
Philippe from Paris
