Author Topic: Strange bolt  (Read 3374 times)
lex280
Strange bolt
« on: May 23, 2017, 20:06:33 »
Yesterday i found this bolt on the drivers side on the floor.
I can't find where it comes from.
Anybody knows this?
Looks like a special one.
Re: Strange bolt
« Reply #1 on: May 24, 2017, 13:53:03 »
Believe that to be the nut to the bolt that holds the clutch pedal to the master?
Looking at your other post about clutch not going in all the way.
Think the bolt has slid out enough to bind against the pedal and frame.
Look under neath there at the top of the clutch pedal arm.
Walter
lex280
Re: Strange bolt
« Reply #2 on: May 24, 2017, 18:19:18 »
if you look at the video, you see the clutch moving completely.
Everything is solid attached to each other.
So it is not from the clutch.
you mean nr 4 on the picture on this link?
http://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/25-26-kupplung-4-gg-getriebe/25-a-kupplung-mechanisch-
Unless i miss something? movement looks normal on video?
« Last Edit: May 24, 2017, 18:23:19 by lex280 »
lex280
Re: Strange bolt
« Reply #3 on: May 27, 2017, 18:02:20 »
So nobody knows this nut?
Looks like a special one to me...
anyone please? :-)
