Author Topic: clutch problem  (Read 2687 times)
lex280
clutch problem
« on: May 23, 2017, 20:20:14 »
So today i was driving i suddenly i felt how step by step i could not push the clutch a lot anymore.
No oil is gone.
On the gearbox (i mean the other pump) everything looks fine.
I guess it is the pump on the inside off the car that is broken
If i press the pedal, you see what is moving, but at the clutch nothing is moving.
So now i can only push the clutch about 1/2 centimetre. (about 1/5 inch) and pedal is not coming back.
All the rest of the movement i got no pressure or resistance.
I attached a link to the movie, maybe this is helpfull.
https://youtu.be/4p5UHo8UvaM
thanks
« Last Edit: May 23, 2017, 20:37:30 by lex280 »
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Re: clutch problem
« Reply #1 on: May 23, 2017, 20:53:36 »
http://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/25-26-kupplung-4-gg-getriebe/25-a-kupplung-mechanisch-
I have the same problem last week.
Not a big work.
The holder with the rubber can be pulled off and put on the new cylinder.
http://www.ge-ma-classics.de/de/Raeder/Bremsen/Zubehoer-Bremse-Kaefer-etc/Bremsfluessigkeitsresistenter-Schlauch-Schwarz-Kaefer
As a replacement for the hose under the reservoir.
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
lex280
Re: clutch problem
« Reply #2 on: May 23, 2017, 21:14:32 »
first of all thank you.
But can you be a give a little more details please.
thanks
lex280
Re: clutch problem
« Reply #3 on: May 27, 2017, 18:15:38 »
Just to give a little feedback.
I took the pump off, the piston was still down. With an m8 bolt i could pull it back out.
Also, my oil was in terrible condition...
So pomps ordered and now oil and should work.
