Pawel and John,
Here are the pictures of my rear suspension Dotology. Pretty confident of most of it. The rear shock lower bolts may be plated and there may not be marks on all the brake lines I marked. I just assumed the assembly was painted black, filled with oil( blue marks on drain and fill plugs), brake lines, calipers, hoses and rotors were added then the unit installed. Spring marking are per application and there is a yellow dot on the inboard face of the control arm only.
