Author Topic: I rolled my pagoda last night...  (Read 72766 times)
johnk
  • USA, OH, Avon
Re: I rolled my pagoda last night...
« Reply #50 on: October 15, 2019, 01:54:20 »
sorry the above pic should have been rotated to show that the car is actually on its side.
Below shows a trick I learned at RM Restoration this summer as part of meeting with the clans. I was very worried before about how I would put the car back together without scratching it. Wrapping the car in shipping foam wrap works great.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #51 on: October 15, 2019, 02:05:29 »
I had a real hard time with my trunk paint getting it to the right level of satin finish, and at $90 a pint plus hardener for the correct PPG gray it was very expensive. In the mean time I used Eastwood's ceramic satin Chassie Black on my gas tank and it seemed to be right on, simple and a quarter of the price. I used it on other undercarriage parts as well.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #52 on: October 15, 2019, 02:24:56 »
As I am cleaning over spray off my wire harness and other parts I am reminded why we take the time to primer parts like the gas tank before the topcoat.  Topcoat over spray comes off easily with a little lacquer thinner but primer requires a lot more effort to remove.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #53 on: October 15, 2019, 02:38:18 »
After cleaning my aluminum last year I coated it with high-temp satin clear Nyalic, but it was very expensive at over $20 a can. For my Cadmium I laid it out and sprayed it with VHT's high temp satin clear which is available at Autozone for $10 a can.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #54 on: October 15, 2019, 02:43:39 »
after spraying
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #55 on: October 15, 2019, 05:44:24 »
Am i reading this right.
You have given the cad plating a high temp clear coat after the plating process was done?
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
johnk
  • USA, OH, Avon
« Reply #56 on: October 15, 2019, 11:01:38 »
Yes to protect the yellow cad from wearing away over time.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #57 on: October 27, 2019, 12:28:27 »
The rotisserie is making the re-assembly so much easier.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #58 on: October 28, 2019, 02:58:35 »
I sandblasted My exhaust manifolds let them sit and rest remover for a week and coded them with ceracote. Ceracote is a commercial ceramic based coating specifically designed for exhausts and high heat application up to 1800 degrees. A local shop uses it for OEM automotive applications.
You only heat it before you spray but not after. I plan on doing my whole exhaust in black but I will have to heat it in my grill. My wife will love that !
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #59 on: October 28, 2019, 03:03:44 »
Sorry For some reason it won’t let me upload pictures of the manifolds
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #60 on: October 28, 2019, 15:46:57 »
They might be too big. Please scale them down...
johnk
  • USA, OH, Avon
« Reply #61 on: October 28, 2019, 20:28:48 »
You are probably correct on that Peter. I used the same camera settings, well I thought I did. Looking now to see if I have the software to scale it down.
John
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
dirkbalter
  • USA, CA, Corona
« Reply #62 on: October 28, 2019, 23:05:41 »
John
John,
I had the same issue. You can use Microsoft -Paint which you likely have.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
johnk
  • USA, OH, Avon
« Reply #63 on: October 29, 2019, 02:28:17 »
Thanks Dirk. I will give it a try.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #64 on: October 29, 2019, 11:04:34 »
Another trick, if you've made the picture on a mobile phone, is to e-mail the photograph to yourself.
The e-mail package will offer to scale it down for you.
Then you can upload the mailed - and scaled down - photograph.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #65 on: October 29, 2019, 11:52:46 »
I use this software to resize pictures. Easy to use and does bulk processing.   This is for the PC.
http://m.majorgeeks.com/files/details/photo_magician.html
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
johnk
  • USA, OH, Avon
« Reply #66 on: October 29, 2019, 15:04:45 »
I tried emailing and texting the pics to myself and for some reason it’s accepting them as is and not giving me the option to resize.  I will try the major geeks software. I tried the “file compression” app but for some reason it can’t find my pictures.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #67 on: October 30, 2019, 10:09:28 »
Hello John
I recommend IrfanView. It's the obvious website, that is, irfanview dot com. Download the free trial version first. Resize is under the "Image..." menu. I have been using it for 20 years, so I paid the guy some money once.
Peter J
1965 230SL #09474 named Dagny
2018 B250 4matic named Rigel
« Reply #68 on: October 30, 2019, 10:52:38 »
I've made some changes so the website should accept bigger files now... and then scale them down.
johnk
  • USA, OH, Avon
« Reply #69 on: October 30, 2019, 19:47:43 »
Let’s see if this goes through now
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #70 on: October 30, 2019, 19:48:27 »
it worked Peter Thanks!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #71 on: November 06, 2019, 23:53:47 »
So ordered a new clutch master cylinder and it doesn’t have the bleeder nozzle (assuming that’s is what it is) on the side like the old one.  Anyone know if I will have a problem bleeding the master cylinder without one?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
johnk
  • USA, OH, Avon
« Reply #72 on: November 06, 2019, 23:57:03 »
Ok looks like I should have gone back and taken a better picture of the new one but needless to say it doesn’t have a bleeder nozzle on it. Same with any new one I find online.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #73 on: November 07, 2019, 00:32:15 »
hhmm, I've never used (or noticed) the bleeder on the clutch master cylinder. I've always bled the clutch using the bleeder on the slave cylinder.
I just noticed that the 230sl and 250sl clutch master cylinders advertised by Bud's both have bleeders whereas the one for the 280sl doesn't. Any chance someone in the past fitted a 230/250 master cylinder?
 https://www.budsbenz.com/catalog/230-250-280-sl/h-transmission-clutch
johnk
  • USA, OH, Avon
« Reply #74 on: November 07, 2019, 02:30:34 »
You are right Charles that mine is probably from 250 seeing that reference, but you also answered my question at the same time. I will bleed the master through the slave valve.
Thanks!
john
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
