I noticed that the brake fluid level drops very slowly. I could not find any leak or even some wetness anywhere on the calipers or lines. It probably dropped an ounce in a year. The level was at the max. line a year ago (first picture).
I found this faint, almost dry trace right under the master cylinder which I believe to be the leak source (second picture). However the BBB shows on the Gen3 master a leak port (B) which appears to be there just for that. I did replace the primary piston and all gaskets on the master 2 years ago.
Is this normal?
