Author Topic: Misfiring at low rpm  (Read 2197 times)
Ebbe
« on: June 12, 2017, 11:28:16 »
I experience some misfiring about 1500 - 2100 rpm. It's primarily when I accelerate calmly. There is nothing when the engine comes over 2100 rpm. So it gets plenty of gasoline I think. I have cleaned the power distributor and checked the power cables. Any suggestions?
Re: Misfiring at low rpm
« Reply #1 on: June 12, 2017, 14:51:20 »
Check the ignition point gap, replace them if needed. Might need a  fresh set of spark plugs?
Ebbe
« Reply #2 on: June 12, 2017, 16:31:28 »
New spark plugs installed 1000 km ago. It is only when i drive very polite and NOT when i accelerate freshly. It is Like the ignition is cut of for a second.
