I decided to edit this post after I did some more tests. The warm up is OK, however it needs a good 5-10 pushes on the throttle to get to the 1200 rpm for warming up. If I do not give it some gas it needs up to 1 minute to raise to 1200 rpm and continue the warm-up. As expected during this time the idle is a little rough. Within 2 minutes it goes down. Recently the rpm reduction at the end of the warm-up is more abrupt than before.
Could this be caused by a thermostat with a sticky feeler that gets stuck extended even against the IP pin pressure? Repeated actuations on the IP linkages may force the thermostat feeler to retract and allow the warm-up process.
Thank you
