Author Topic: Nardi Wheel Hubs  (Read 4711 times)
Nardi Wheel Hubs
« on: April 28, 2003, 08:16:35 »
Does anyone have access to the Nardi wheel hubs for the various W113 steering columns?  I assume that there was a hub made for the earlier 230SL columns, but I can only find the hub for the later cars (which does not permit horn operation on the earlier cars).
Would appreciate any info from the members.
Lowell Paddock
1966 230SL
JimVillers
  • USA, VA, Virginia Beach
Re: Nardi Wheel Hubs
« Reply #1 on: April 28, 2003, 14:28:01 »
I just installed a Nardi wheel on my 230SL with a hub #3319.  The wheel is about an inch higher than the normal wheel and I was able to make the horn work with a little work (insulated the ground pin on the horn contact ring).  The #3320 hub will not work with the horn connectors and it is at least another inch taller than the #3319.
Jim Villers
Jim Villers
