Author Topic: Cigar lighter  (Read 2925 times)
ronaldwardmd
  • USA, CA, San Francisco
    • Ronald Ward, M.D, F.A.C.S.
Cigar lighter
« on: June 24, 2017, 02:00:37 »
Cigar lighter, 280SL, appears to be shorting out, burns up the fuse (25). Wipers and washer work fine. Will replacement of lighter element solve problem?  Appear as though radio must come out to remove old element and install replacement part.
Ronald Ward MD
Larry & Norma
Re: Cigar lighter
« Reply #1 on: June 27, 2017, 16:47:46 »
Is it only blowing fuses with the lighter element in place? From memory the socket has a small fibre
washer which is all that prevents the unit shorting. You will need to take the unit out to investigate.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
