Author Topic: Fuel sending unit repair  (Read 3548 times)
dirkbalter
  • USA, CA, Corona
« on: June 25, 2017, 20:41:31 »
Hello all,
I am attempting to repair my broken fuel sending unit. One of the lower taps of the u-type wire is broken and needs to be re-soldered. My question however is regarding the routing of the wire on top. I attached to picture. I routed the wire through the gaps or hooks in the plastic bracket. In doing so, the wire will touch the metal hex nut and stem. I don't believe that's right. Does anybody know or even better, have a picture of how the wire is run?
Thank you
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mbzse
Re: Fuel sending unit repair
« Reply #1 on: June 25, 2017, 20:53:32 »
Quote from: dirkbalter
.../... does anybody know or even better, have a picture of how the wire is run
Try this. In the second picture, I have tried to enhance the wire routing in red
/Hans S
dirkbalter
  • USA, CA, Corona
« Reply #2 on: June 25, 2017, 20:59:47 »
Hans,
Excellent.
Thank you.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: June 26, 2017, 14:33:36 »
Many W108 sedans of the era used the same sender, if you can find a good used one.
dirkbalter
  • USA, CA, Corona
« Reply #4 on: June 26, 2017, 16:29:03 »
Thanks for the tip.
I will give the soldering a try and see if it works. Is there a way to test the unit (meter it out between the poles)?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mbzse
« Reply #5 on: July 02, 2017, 15:11:11 »
Measure resistance between "M" and "G". Should read some 70 +/-1,4 ohm when float is at bottom and 4,7+/-0,4 ohm when it is at the top. This is what affects the red needle in your instrument binnacle fuel gauge.
"W" is for the red "near empty" warning light.     Masse = Ground
« Last Edit: July 03, 2017, 10:40:03 by mbzse »
/Hans S
Anthony
  • Belgium, Flanders, Deerlijk
    • www.classic-mercedes-parts.com
« Reply #6 on: July 03, 2017, 09:01:33 »
We're expecting a new shipment repro fuel sender units for the later W113 models any time now in case you're not able to fix the current unit.
dirkbalter
  • USA, CA, Corona
« Reply #7 on: July 04, 2017, 23:05:57 »
Hans,
Thank you for the help. I soldered the contact but than slipped and snapped the wire in an attempt to route it before I even got to measuring.
Anthony thanks as well. I just received a new one from the mb classics center here in Irvine. (Fairly reasonable price I believe)
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
