Author Topic: rubber boot mats?  (Read 6980 times)
ohoraherecaptain
rubber boot mats?
« on: June 26, 2017, 18:40:27 »
Hi Guys.
Any recommendations on where to purchase a rubber boot mat for a 280?
Germany/US?
JOH
JOH
Re: rubber boot mats?
« Reply #1 on: June 26, 2017, 18:51:17 »
In the States, KKMfg shows "call for availability", Buds Benz has them listed on their site at US$439. SLS only showed the small mat.
Pagodarestorer23
« Reply #2 on: June 26, 2017, 19:33:07 »
SLS do the carpet version which is actually very nice! They didn't have rubber in stock last time I spoke to heiko there.
If you call Kk manufacturing speak to Tim he's great and knows his stuff!
« Reply #3 on: June 26, 2017, 20:54:29 »
Personally I advise owners to have a carpet instead of rubber; it gives less condensation and therefore longer boot floor life.
alpina
  • Spain, Asturias, Villaviciosa
« Reply #4 on: June 26, 2017, 21:18:33 »
ohoraherecaptain
« Reply #5 on: June 27, 2017, 10:53:00 »
Cheers Colin. Ever come across a German company known as K.H.M.?
JOH
ohoraherecaptain
« Reply #6 on: June 27, 2017, 11:13:14 »
Any suggestions on where to get one?
JOH.
JOH
« Reply #7 on: June 27, 2017, 15:09:44 »
They are in our vendor list. http://www.cabrio.de/en/
ohoraherecaptain
« Reply #8 on: June 28, 2017, 17:26:31 »
Cheers.
JOH.
JOH
« Reply #9 on: June 29, 2017, 03:50:20 »
Another option is using cocomats in the trunk. I have that on my W111 and they are super durable.
« Reply #10 on: June 29, 2017, 11:49:33 »
From what I have seen the eBay mat is the only new on currently available that is correct for our cars.  It was molded with an edge of approximately 19mm around the perimeter.  The rest are simply cut out of a sheet of ribbed rubber.  There is a rumor that Mercedes is looking into having more made and sine the show judging standard is original or whatever is currently supplied by Mercedes Benz those mats will also be correct.
Since it would be very expensive to produce a new mold to recreate the original trunk mat I assume any later mats from Mercedes will not have the 19mm edge.
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #11 on: June 29, 2017, 13:49:19 »
In case you don't know, Cocomats will make that mat without the rubber bottom. That's how I had it made in an effort to allow the trunk floor to "breath".
I do need an original one also. I'm hoping MB comes up with something very nice. I'm not in a rush.
1998 BMW M-Rdstr Estoril Blue
« Reply #12 on: June 29, 2017, 14:55:34 »
The cocomats with the rubber bottom usually have dimples on the backside and should in theory allow some air between the rubber sheet and the trunk floor. But if you experience heavy condensation in your situation, probably best to do away with the rubber bottom. I would imagine it's main function is to hold the dirt from falling all the way through, making it easier to clean.
  • USA, WI, Mequon
« Reply #13 on: June 29, 2017, 15:11:20 »
I've had my cocomat with a rubber bottom over an original rubber mat for 10 years and my original trunk floor still looks like new.  Unless you have moisture in the trunk for some reason, rubber appears to be a non-issue.  My car has a pampered life, climate controlled garages, driven on nice days (6000 miles), never washed in 10 years!
ohoraherecaptain
« Reply #14 on: July 08, 2017, 16:38:18 »
Cheers Wallace. Do you know if they fit the W113?
JOH.
JOH
ohoraherecaptain
« Reply #15 on: July 08, 2017, 16:50:02 »
These pictures are stunning.
Thank you, John, for sharing them.
What a beautiful thing!
JOH.
JOH
« Reply #16 on: July 09, 2017, 20:47:20 »
They are custom made and I do believe they have a pattern for the W113.
« Reply #17 on: July 10, 2017, 05:39:13 »
Even if the folks at Cocomats don't have the pattern, it is not a tough thing to get done. I have had several custom mats made for other cars.
When you contact them, they will get you set up. I had a large piece of brown paper that I just laid in the area (back of E wagon), cut it to fit with a pair of scissors, sent it back to them and they made the mat (with the indentions for the hold down connections). It was a perfect fit.
  • USA, WI, Mequon
« Reply #18 on: July 10, 2017, 12:04:06 »
my cocomat in the picture above in the trunk is from Cocomats.com and obviously they have the pattern (to a T)
