Author Topic: Speedometer gear  (Read 3971 times)
rgafitanu@gmail.com
Speedometer gear
« on: July 10, 2017, 20:56:23 »
Anybody knows which gear set matches the differential ratio? The speedometer worm gear set in the transmission, the gear set inside the speedometer or both?
Thank you,
Radu
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: Speedometer gear
« Reply #1 on: July 11, 2017, 03:45:23 »
Hello Radu,
Years ago at one of the PUB events it was explained to me that there are no gear sets in the speedometers.
The calibration is done by fine tuning the adjustment of  a very precise drag clutch on the main shaft.
Other than by  than by trial-and-error, I am not sure how this is done - - -.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
450sl
« Reply #2 on: July 11, 2017, 12:40:00 »
at the transmission all speedo gears are the same ; calibrating is done at the speedo.
mbzse
« Reply #3 on: July 11, 2017, 13:52:57 »
Quote from: Radu G
The speedometers are different; and each type is matched to the respective differential ratio.
On the speedometer rear, you see a stamped marking, for instance "W=945".
This means for 1 kilometre distance and a 1:4,08 rear axle, one has 945 revolutions.
The table for each type used in our Pagoda cars is:
1:4,08 rear axle diff ratio: 945 rev´s. W= 0,945
1:3,92 rear axle diff ratio: 908 rev´s. W= 0,908
1:3,75 rear axle diff ratio: 869 rev´s. W= 0,869
1:3,69 rear axle diff ratio: 855 rev´s. W= 0,855
/Hans S
rgafitanu@gmail.com
« Reply #4 on: July 11, 2017, 16:07:27 »
Thank you Hans,
That means that I would need a speedo stamped 0.757 to match the 3.27 diff.
mbzse
« Reply #5 on: July 11, 2017, 17:31:41 »
Quote from: Radu G
.../... I would need a speedo stamped 0.757 to match the 3.27 diff.
I guess so...  However, such a speedo was never produced by VDO for the W113 Pagoda (nor a 0.801 version for a 1:3.46 diff)
Perhaps a unit from a sedan(limousine) or coupé could be installed (?)
« Last Edit: July 11, 2017, 17:37:15 by mbzse »
/Hans S
rgafitanu@gmail.com
« Reply #6 on: July 12, 2017, 12:58:54 »
You are right, 3.27 diff's were made only for W108/109 and the V8 W111 (I think).
