Author Topic: window seal repair advice  (Read 3542 times)
William Dabney
  • USA, VA, Richmond
« on: July 15, 2017, 18:12:57 »
so i pulled the interior panel off my driver's side door of my 1968 250sl to replace a broken door lock above the window crank. all that went well so i have decided to replace the rubber/felt/ ??? things at the top of the window channel in hopes of cutting down on window rattle. it looks pretty simple to unclip them but where do i find info if that is the correct way to get started. more importantly, if i do get them off, where do i find replacements? also feel free to let me know if my thinking is wrong about prying them off "clips".   thanks, billy bob
neelyrc
  • USA, AL, Birmingham
Re: window seal repair advice
« Reply #1 on: July 15, 2017, 20:32:05 »
billy bob
If you have not already checked out the Technical Manual on this site, it is always a good place to start when you need information.  Have a look here:
https://www.sl113.org/wiki/ChassisBody/Windows
For additional information, try the main "Search" function (fourth button from the left at the top of the page).
Also take a look at the list under "Suppliers" in the Technical Manual.
Best of luck with your window and door repairs.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
William Dabney
  • USA, VA, Richmond
« Reply #2 on: July 15, 2017, 20:54:21 »
thanks. i was fixated on the interior trim page.  best to you
« Reply #3 on: July 16, 2017, 07:02:48 »
They do just 'slide' off with some force. I believe new ones are available from various suppliers. SLS in Hamburg for example seems to sell the (I think they're called) 'whiskers' by the meter, or as a pre-cut set together with new clamps.
hkollan
  • Spain, Castilla-La Mancha
« Reply #4 on: July 16, 2017, 07:56:07 »
I recommend getting the 'whiskers' from MB original, although even they are slightly different than the orignal ones from the production days. The cheaper version of the repro parts offered by SLS and others are more or less worthless even if the price is tempting. The OEM-like version they offer is better/thicker but still not quite right.
While you're in there, I would also suggest to thoroughly check all the glued glass guides and plastic guides. Their failure is usually the cause for rattling windows.
Hans
Hans K, Cuenca, Spain
450sl
« Reply #5 on: July 16, 2017, 08:06:08 »
You might first want to check if the guides are present and well adjusted....
