Author Topic: Instrument Cluster Glass Removal  (Read 3899 times)
StevenF
  • USA, NY, Merrick
« on: July 18, 2017, 16:20:15 »
Can the chrome piece and glass be removed from the Center Instrument Cluster from the outside?
1971 280sl
Red Metallic
Bamboo MB Tex
Re: Instrument Cluster Glass Removal
« Reply #1 on: July 18, 2017, 16:49:12 »
No.
Remove the tack first and then the center cluster after that. The chrome bezel is somewhat delicate but it will come off using a small tool like a screw driver to carefully pry back the chrome trim. Make sure you have the trim loose all the way around the cluster or you can crack the glass at the hole for the instrument lighting dimmer.
« Reply #2 on: July 18, 2017, 17:59:07 »
And also note that the instrument cluster dimmer knob is mounted to the glass and will slide off when you remove the glass. As the Benz Dr. notes, be quite careful removing the chrome trim, it is delicate, but can be done, just use a bit of patience and you should not have any issue.
« Reply #3 on: July 18, 2017, 19:01:47 »
You can actually re-use the chrome ring and just crimp it back in place, if you want, so long as you're careful - no need to buy a new one.
« Reply #4 on: July 18, 2017, 23:16:53 »
[/quote
Yup. I have quite a few times.
